let me check the FAQ's and ill get back to ya
i checked the FAQ's and it says 72 i havent been on the fourm THAT long to have heard about going 20ftlbs over, i think useing the proper moly lube the 72 should be just fine( the arp studs should tell you what lube to use and what torue settings, only if there specific to your car tho) heres a link of the FAQ'S which explanes just about everything
http://www.supras.nl/index.php?optio...d=26&Itemid=42
P.S in my opinion if you got the heads out and putting a new head gasket might as well go whith MHg just because your there and that little extra will give you peace of mind down the road and if you want to go a bit higher on the HP level you dont have to worry about it
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
