I will take a picture once I get home from the Kentucky Derby but if I don't have a second fuel pump, would I just have to install a second pump instead of buying a fuel system? What else I guess would I need to be able to run 650whp through 750cc injectors and fuel rail?
I will let you know as well what size tires and rims I have once I get home. But all together does the 67mm turbo kit from Sound Performace look like a good choice to go with then? If so, what a/r should I go with? .68 or .81?
