Thread: issues
Old 05-08-2012, 05:11 PM   #1
Dues Ex Machina
Dues Ex Machina is on a distinguished road
did you see what codes are stored? did you check the tsrm trouble shooting flow chart?
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=14
I haven't checked the codes yet. check engine light isn't on so I didn't think about checking them. will check them anyways soon and see if it throws any. yeah I checked it. the symptoms that I had it said to check vacuum lines. as far as I can tell vacuum lines are fine except for vsv missing. the one on drivers side on the bottom side of engine.
also, since we changed battery and tweaked idle and tightened that bar going to the throttle, it feels like it runs stronger. it used to feel sluggish
Dues Ex Machina is offline   Reply With Quote
