Ok now im offical pissed i done get me used known workin afm n it dunt make the code go away bt unless im glad it finally didnt die on me everytime now couple stops will die
(Ps) i jus did flush coolant out n fill it up wit red toyota yes i made sure only water comes out and bleeding it the line has dropped under half with no problem bt it hella smokey alot more than used it used to. Not because of water its bone dry already.
