Old 05-23-2012, 04:12 AM   #1
If you're referring to the lower, rear timing belt cover there are bigger things preventing you from pulling it.... The head gasket seals it at the top and because of the oil seals in it you can't slide it in and the up (in which case you'd still have to loosen the pan but you'll never get it to seal without pulling it and thoroughly cleaning it).
The short version you don't want to hear: pull head & pull oil pan.
