like cre said in the second post. you can manually check error codes on both ecu's. try searching around and see what comes up for the 82 style ecu.
i would really check
www.celicasupra.com search everything. once agian, you can test your AIR FLOW METER. your car has NO "maf"
refer to your repair manual for testing.
