under 4k seams reasonable with the above stated mods/parts. with the amount of wiring and everything that needs to go one, parts can add up quick as well as labor. driftmotion sells about everything under the sun for the 1jz swap so use them to your advantage, i think your getting a decent deal for someone doing the work for you.
