Originally Posted by akue
Ok so the cable was bad it was almost off the ground I put it in a new location from where it broke and still have no power
You probably need a new cable, do an ohm check to see if there is any resistance. make sure all of the connection points are clean. need to be sure the cable is connecting a good electrical path from car to ground. did you try a voltage test from positive to body of car? If there is no voltage indicated then the ground is bad.
