if your rack leaks that could be the directonal issue, as a quick fix i would go to the FAQ's and check how to flush the ps system and put in lucas ps fluid whith stop leak( it stoped my leaking for about a month) could be that during a bump you hold the wheel straight but that loss of pressure some where in the system is what causes it to wounder.
I think I'll just swap the tires before my trip and just drive like that for a week
that seems like a good option, i wouldent worry about tire wear so much the rack its self doesent cause that other suspension components would, try the flush and lucas see if that is a temporary fix
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
