Old 06-18-2012, 10:37 AM   #1
Awyman18
Awyman18 is on a distinguished road
Default Clutch master cylinder leaking after 8 months?
Ok so like the title says my clutch master cylinder is leaking...I replaced the factory one on my 1990 supra turbo maybe like 8-9 months ago. Its where the cylinder goes out from the the engine bay through the firewall to the actual clutch itself. The weird thing is tho that their is ALOT of fluid in the reservoir.. And i haven't filled it recently except for when i reinstalled the bad one 8-9 months ago (also i did look and check the fluids regularly) which i dont get because somehow more fluid got added...? so im kinda confused........could it be only leaking because there is too much fluid?
Awyman18 is offline   Reply With Quote
