Old 06-18-2012, 02:08 PM   #2
pandrade
pandrade is on a distinguished road
I might be able to help since i replaced mine a year ago and i havent leaked since. is it leaking into the interior and carpet or out into the firewall, and also did you properly adjust the pedal play. if your saying its leaking and you havent filled it up any more, it could be a few things but i kinda need to know its it leaking into the the interior or out into the fire wall
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
