Old 06-24-2012, 01:47 AM   #1
carl johansson
carl johansson is on a distinguished road
Default can you add Trans fluid through top - W58?
Can you add trans fluid to the W58 through the shifter hole in the top. i've done it through the side hole before, but it was a PITA. it would be real easy to just dump it in through the hole before I put the shifter back in.
and something like 80 W 90 oil? right
carl johansson is offline   Reply With Quote
