I know how to use a multimeter, I just need to know where to look next. The problem like I said before is that I dont even get power when the car is hooked up to jumper cables. So Im not quite sure what voltage drop would have to do with it. I do know that on the battery I have 12v. That is as far as I have looked though. Cre you saying I need to go through and check every fuse as the next step?
