first check for codes in the system heres how
http://www.toyota-supra.info/forums/...tic-codes.html
if you have a super moniter( the thing in your dash whith 4 buttons that tells time,mileage,oil change and date) press( from left to right it will be button 1,2,3,4) the # 1 and 3 it will say error keep holding until it says diag then press #4 and it will say eng let it read the codes untill it gets back to eng. write down all codes here it will tell you what each code means, it will also tell you how to check codes if u dont have the super moniter
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
im no expert ( that would be cre) but the whoosh u hear at boost could be a boost leak
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
