I stumbled across some of those yesterday, but I was unsure about them because I'm not sure what fitment I need. I guess I expecting one to be specified for a mk3 Supra. I just measured the fan I currently have on my car and it's 14" diameter and 1.5" wide, but it mounts directly on the radiator since it's electric. Also, I'm pretty sure the radiator that's on there isn't the original, although it may still be OEM, not sure. Will this affect anything?
Also, I'm not sure what clutch to look for either. From what I've heard, a factory fan clutch won't work with these flex fans right? Are the clutches specific to each fan model?
And thanks for your advice about the extensions. I guess the size of the extension I need will vary depending on which fan I decide to go with, but how will I know how close the fan needs to be? I don't have the factory shroud to use as a guide.
