07-12-2012, 09:09 PM
#2
Supra Owner
Originally Posted by 2jzPower
I have a Japanese import 94 model MIV and after some research I've found that on the US models you can remove a fuse for the traction control and speed limiter, does the same apply for the Japanese models and are there any negative effects to doing this?
All info is much appreciated.
Simon
http://mkiv.supras.org.nz/techo.htm#SPEED_LIMITER
Life begins at 30psi.
