Old 07-20-2012, 04:13 PM   #2
hermanonthemoon
hermanonthemoon is on a distinguished road
Originally Posted by xThermoNucleaRx View Post
I'd be wary due to the 1jz swap. It's going to be extra work if something ever does mess up since you don't know how the custom build was performed (especially with the twins set up). However, from what I read, the 1jz is suppose to be better than the 7m so if you can get a look at the engine and give it a hard test drive then maybe it's worth it.
Overall though, price wise and the condition it's in, is it worth dealing with? I know once you start modding a car with a turbo its bound to start shitting on you eventually, so do the pros outweigh the cons? When you said looking at the engine, anything in specific I should be checking for? I heard the main thing you should check is engine compression and for boost leak. Anything else really that I should check for this car in particular? And I appreciate the repsonse, thanks!
hermanonthemoon is offline   Reply With Quote
