Did you use the oil pressure sender from your original engine? Where's the new engine from? Have you checked the wire to the sender for a good, clean connection and any signs of damage? The oil pressure sender used in 7M in some other markets (primarily Japan) differ from that used in North American models.
Check the wiring and get a mechanical gauge connected to determine if the problem really is mechanical or just electrical.
