Yeah so my swap is a JDM engine, and i am not using the sender from the original. I checked the wiring that comes from the ECU/Cluster that connects to the engine and it checks out good, it gives a reading when we tested it. So should there be something else i should check? Or do you think a quick drive might do the trick? Because i have only started the engine leaving it idle and reved it a little bit, but never drove it on a test run or anything
