The JDM sender won't work with the USDM gauge cluster or 7M-GTE ECU (the 7M-GE doesn't get an oil pressure signal so only the gauge on the GE is relevant). The JDM sender is smaller than the one found in North American models. If it's smaller than your original then swap your original sender back in. I wouldn't go for a drive or even rev it hard until you verify that the problem isn't oil pressure.
