Old 07-27-2012, 03:21 PM   #50
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fastsupra View Post
Should I plan on purchasing the TRD LSD? I see a lot of people with them but was wondering if I should get it or not.
As you increase your horsepower level, the TRD LSD will help you accelerate smoothly and straight forward during wheel spin. With the oem torsen-type lsd, your rear end will tend to pop over to the right when wheel spin hits. Note that for roadracing with good tires, wheel spin isn't usually an issue - so a TRD LSD could actually hurt your lap times, since it can cause some speed to be scrubbed during cornering.
If you roadrace, this may be a better option:
http://www.mvpmotorsports.com/Templa...210&SearchYN=N
Search for part number "Cu LSD168K15"
Life begins at 30psi.
