Thanks for posting some numbers Sonyps307. If you had two different speeds for the fans how do you think they would be best employed? I'm thinking turn on on low speed to help clear some heat out of the engine bay (popular mod on the MR2 but heat's a little more of an issue given their engine placement) and then hold off on high speed until you're sure you need the extra airflow.
