do u think a set of the npc's would be ok then? cause if i get that set i get rings, pistons, and connecting rods
edit: Ill just get the NPC rings. Just rings for 44 bucks. As long as you havent had a problem with them i dont see why i would either
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
