Old 08-13-2012, 05:02 AM   #1
icey756
icey756 is on a distinguished road
Default Question on oil catch can. PCV valve?
I would like to install an oil catch can when i put my car back together since its going to be extremely clean. I would like to keep it that way. In the diagram below it says to put in a PCV valve or check valve. I did some searches and im still confused on which one I should get. Also that diagram is only for the pipe i have circled in green. What about the front thats circled in white? Should that some how get routed to the catch can as well? Any input is great or pics on how yours is installed is even better.
ID:	4651   Click image for larger version
Name:	DSCF3003 with circles.jpg
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
icey756 is offline   Reply With Quote
