before u do any mods - my advice to you would be to
1) find the soonest local drift event
2) get some used 15 or 16'' v6 wheels with tires to learn on
3) go to the event see how you like it, find what you wanna improve on and go from there.
i suggest doing some of the fluid swaps before you push it though. Tranny, Radiator, Differential, Engine Oils all swapped. Take your car to the track and spin it around for awhile, you shouldn't do any handling mods at first, learn to drift stock. it will make you a better driver.
then id do some research and find out what your car can do better, whether you have oversteer, understeer, bodyroll, etc then id look into parts that will eliminate any problems u are having
