Old 08-21-2012, 06:39 PM   #99
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Hi. i have a bit of a problem i cant find my vsv valves on the turbo side what will the managment do with out them.
All plug-and-play standalone engine management systems can be configured to ignore these VSVs if you go to a single turbo setup. For the oem twins, the appropriate map for that plug-and-play standalone ecu system will already be configured to recognize those VSVs on the appropriate oem harness connector pins.
Life begins at 30psi.
