I guess i found the problem...apparently a simple one. A small tube that was supposed to be attached to the air intake (just next to the MAF sensor), was disconected! After i reconnected it the engine stop stalling and no more misfiring. However, the bad news is, i removed the spark plug from cilynder n?6 and i found oil on the galley...any ideas of what the cause might be? A bad valve cover gasket??
Thks!
