Old 09-02-2012, 11:30 PM   #107
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
..3)Ran wires through the top of tank sealed them with srink strips..
What's a srink strip? Again, this probably won't work. Fumes and vapors will come up the insulation - it acts like a hose (even though some of the space is blocked with copper strands).
..5)Do i need the the FPD wont the aeromotive FPR sort that out.
No. How are you planning to feed the other end of the fuel rail? The FPR usually connects in line with the fuel return, not the fuel feed line(s). The FPDB goes between the oem fuel filter and one end of the fuel rail. There should be one line between your new fuel filte rand the other end of the fuel rail.
Note: You *can* hook the FPR into one of the lines feeding the fuel rail. In fact, you can "T" the two fuel lines into one and "T" the FPR into that line, and then send it to one end of the rail with the other end blocked off. However, all of those designs are inferior for one reason or another. Let me know if you want to get into more detail.
Life begins at 30psi.
