Old 09-03-2012, 12:46 AM   #10
Wileyk24
Wileyk24 is on a distinguished road
Default Update
Sorry for the long delay between posts, my car died, my computer died, and my dryer died all in the same month lol. So I am reporting in via iPad. I did take tons of pictures and notes so I will be putting up a how to once the computer issue is solved.
So...I got the car all back together tonight, filled with oil and coolant, cranked for 10 seconds without spark, added spark and cranked for the first time. After some sputter and coughing it did fire up, but it won't stay running unless I press on the gas. When I do hold the gas it does run but not well.
I checked the timing via pulling the cover and ensuring the pulley marks lined up while the crank is at 0 degrees tdc. Everything lined up great. I looked into the oil cap hole and see the cam lobe pointing up. I even pulled the number one plug and put my long ratchet extension down the hole to ensure the cylinder was indeed at the top of its stroke. It was. The CAS was dead center, I was waiting for the car to idle before I made any adjustments to it...but I have yet to get idle.
I also double and triple checked my vacuum lines against the diagram on Cygnus site.
What gives? Any ideas?
Wileyk24 is offline   Reply With Quote
