Thread: code 34 fixes
Old 09-06-2012, 02:15 PM   #2
pandrade
pandrade is on a distinguished road
the bov is good( i tested it by trying to blow air through it and it wouldent allow air throught) now to test the actuator should i just pull the little arm and see if it has a full range of movement? oh and lately around when this problem has started i would get a big puff of blue smoke on start up, it always did this but since this code and problems started rearing its ugly head its been getting more common( at this point is at every start up)
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
