Old 09-12-2012, 09:20 PM   #1
dwthomas42
dwthomas42 is on a distinguished road
Default idle problem fuel pressure up vsv 7mgte
Ok I have a 1987 supra 7mgte with a r154. My idle drops when I brake or hold the window switch down and idle will drop down to 500rpm when left sitting. And my fuel pressure up vsv has a broken wire. When should the vacuum from the vsv stop. Would a bad brake master cylinder cause the idle to drop? Any help would be greatly appreciated.
dwthomas42 is offline   Reply With Quote
