Old 09-15-2012, 06:27 PM   #10
1989toyotasupraandpickup
1989toyotasupraandpickup is on a distinguished road
I did not have this problem before I installed the maft pro. There were also no trouble codes before. Now I have code 24 the air temp sensor. Um when the problem happens sometimes I get code 34 boost pressure abnormal. I only get it sometimes tho when I blip the throttle. There are no boost leaks as I could see or hear. No vac leaks either
1989toyotasupraandpickup is offline   Reply With Quote
