Old 09-16-2012, 05:54 PM   #1
johnmfoschi
johnmfoschi is on a distinguished road
Default Clutch slave cylinder leak
my clutch reservoir when empty and I filled it but did not bleed it. Since filling the reservoir I have smeller burnt brake fluid so I have searched and found fluid in the rubber boot between the slave cylinder and the transmision. Any idea as to what I should do? Could this be caused by not bleeding the air out of the line? Is this a sign that the slave cylinder is bad and should be replaced?
johnmfoschi is offline   Reply With Quote
