Start by checking for diagnostic error codes. The process is covered in the FAQ section. If the battery has been dead or disconnected you may need to run the car for a little while before any error conditions are logged again. Most codes require that the vehicle be driven under varying conditions and in some cases a number of occurrences must be noted before a code is logged by the ECU.
