Okay. I installed an aftermarket Aeromotive regulator with steel braided lines set within factory specs.
All seemed great yesterday afrs were where the should be around 14.7 so I parked it and then while driving to work this morning guess what came back! The lope in the idle.
Agghh. The CEL did come back on and I will be checking that at lunch time and will update that info. I have no idea what's goin on.
Is it possible my headgasket is seeping? Although I am not missing fluid.
I put some new fuel in it with some injector cleaner so time will tell of that helps at all.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
