Like cre said the coolant and oil systems are separate. Even if it is your coolant is leaking it should not be mixing with the oil. Inside the head are coolant and oil passages the are separated by the head gasket. Again like cre said there doesn't have to be a leak into the cylinders to have a bhg. Therefore your compression may still read normal.
