Old 09-21-2012, 01:19 AM   #16
Travis89Turbo
Travis89Turbo's Avatar
Update
I switched the o2 sensor to the rear bank and what do ya know it started acting up again stumbling on idle just like before afrs drop lean.
So I ohm'd the injectors they all checked out within limits.
So tomoroow I will be gettin a new leak down tester and an adapter for my compression gauges as I didn't receive it back after I loaned it out.
Fluid levels still look great. No mix in any fluids so I am starting to wonder about my piston rings. ??
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
