Originally Posted by Travis89Turbo
...My question to you is should I dis connect it at the throttle body or will it hold 50psi??
Everything should hold about 50psi bone cold. This is the equivalent of about 25psi running hot under boost. If things pop apart at 50psi or less, it just means you need better t-bolt clamps & couplings.
