Old 09-28-2012, 01:50 AM   #10
1989toyotasupraandpickup
1989toyotasupraandpickup is on a distinguished road
How exactly do you disable ptt and wot tracking. I set the idle tps to 0 and the cruise tps to zero under the ptt menu. then i went to the wot menu and put the mintps value to 0. Plugged the oxygen sensor took the efi fuse out for 30 seconds then put it back in. Drove the car for a few minutes and ran great but all of a sudden the car started to bog down and misfire real bad. could not go over 20 mph. the afr gauge said very lean when all this happened. it was choking by not having enough fuel.
1989toyotasupraandpickup is offline   Reply With Quote
