Old 09-30-2012, 07:26 PM   #1
interested!
Question cockpit brake lamp
Hi! I am having a problem with the cockpit brake ( red ) lamp , this is coming on while I am moving and braking . It goes out when moving off -handbrake released , but comes on almost every time I depress the footbrake pedal ,even lightly . The reservoir is topped up to max ,the reservoir switch works , comes on when free of the reservoir , goes out when fitted . Any ideas anyone ?. Only seems to come on when the engine is running and the brake pedal depressed -even at rest! the ABS lamp is NOT lighting up at the same time , , the pads are good , and braking in a straight line .
