Old 10-02-2012, 01:48 AM   #28
vikenabm
vikenabm is on a distinguished road
Default OK good luck
I'm terribly sorry for your grandfather. I'm a medical doctor and know exactly what you are saying. I'll post here as a sketch pad in your absence in case anyone with a similar problem stumbles on the thread. Between the cam timing and trying the stock injectors I think I will have my answer. thanks.
K&N filter to Lexus AFM | 660cc RC | Holley 255 LPM FP | JE/Eagle internals | 2.5" hard pipes | Toyo high flow intercooler| S Sanchez ported head | 1.2mm beaded MHG | compression 9:1 w/0.5 overbore | modified ex mani | CXR 3" full exhaust | Slotted/drilled rotors |New WG spring @12psi w/ dual switching man boost | Colt Mild perf. Cams | Bosch BOV | XTD clutch | Tokico Illumina w/TEMS | ES bushings | 18" Pirelli P-zeros | Man AFPR | zeitronix wideband w/EGT probe | on-board race timer
vikenabm is offline   Reply With Quote
