There was a big discussion (on SM?)on the # of fan blades from year to year. 10 seems to be the desired fan. I believe you can use the newer year setup on yours. The little fans on mine come on when a/c is on. You could easily wire up a relay for each fan and a temp sensor kit for them. I also ran a manual over-ride switch inside to have more cool-down control.
