I recommend getting an alignment done anyway about it. The alignment may have been set since the bushings began to wear and setting the alignment bolts to the same position could still put the alignment a mile off with new bushings in place.
I also recommend you get the housings fitted with nipples for a grease gun. Urethane bushings need periodic lubrication or you may find the suspension has more creaks and groans than an old, haunted house after a year.
