Need help making power 94tt
So the exhaust is done and the boost pipes wil put up some picks.
Started the car and had a oil leak almost thought it was the head gasket stripped the car today to find out it is the cam seal that is leaking dont know why.
I cant find new seals only seals toyota can get me is the 2jzge seals so my question is are the seals the same as the 2jzgte.
Also the tuner cant get the chip to pick up the rpm signal from the ecu so hopefully he can sort that out after i fix the oil leak.
