Thread: no fire
Old 10-26-2012, 10:38 AM   #1
interested!
Question No Fire
Originally Posted by bigboy View Post
i have 88 turbo im not getting fuel or fire and i put new fuel pump in it neone know what problem could be im new at owning this car i switched over from honda to toyota
Hi! Questions ? was the car running before you changed the pump - why did you need to change it ? , is the new pump working ? ( live? - check the fuse ! ) ? , how much petrol have you got in the tank ? , did you reverse the piping when you fitted the new pump ( could be an internal blockage ! ) . Create a check list ,ticking off as you go through it .
