Originally Posted by consol1
I have read the FAQ's and searched the fourm have not found my answer yet? What is the max WHP I can produce with these things on pump gas...
What is the spec of the pump gas where you live? A BPU Mkiv TT won't do more than about 350rwhp on pump gas. Have you considered meth injection?
...Can I replace them with turbos that will spool faster and produce more hp(ball bearing?)...
NO. Pick one - faster spooling or more hp. You can't have both. It's simple physics - a bigger, heavier turbine+compressor wheels take more energy to spool up. Can I eat more, exercise less and lose weight? Silly question, right? Yours is just as silly. Sorry just being honest. Newer technology turbos make a small % difference, but the general answer to your question is still pretty much a flat NO.
...Do I need bigger intake, cooler, exhaust, and a chip to make them be more efficient....
No, but all that stuff will help you to make more power with race fuel (or meth injection) and higher boost levels.
...I get that bigger sometimes means more lag and I don,t want that. I want this car to be fun and dependable. Any ideas?
Lag is easy to deal with if you have a 6spd - just downshift! With an auto, it's a bit tougher - you need a high-stall torque converter. Either way, lag is overrated. Get a bigger single turbo and you won't regret it.
