Old 11-19-2012, 01:21 AM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by consol1 View Post
…I know myself pretty well and one thing I am sure of is the kind of horse power that I will want in the end will not be the kind I can control at the beginning…
Don’t forget you’re dealing with a variable horsepower car. Just because we build it for a particular horsepower level *max* doesn’t mean you can’t turn down the boost (for whatever reason).
…Stand alone systems are more dependable then adding a chip or other programs in my opinion…
What could be more reliable than the thousands of engineering hours that Toyota put into the stock ecu. Depending upon your horsepower level, the oem ecu could still be the best (and most dependable) choice.
Also note that an aftermarket ecu requires a map – likely configured by someone other than a certified automotive engineer - and that map (or maps) most likely will not have even 1% of the time that Toyota put into developing the stock map. Please trust me that this is a major consideration for not only peak-horsepower tuning, but regular drivability. In fact, peak horsepower tuning is almost a trivial job compared to getting cold-starting, tip-in, and all-around drivability just right in various temperatures, humidity levels, and altitudes. In short, when you make the move away from the oem ecu, it is a *major* step. We can get you 600rwhp with absolutely no issue at all, with the oem ecu. Please consider this before we make the final call on dumping it.
…Plus you can't run 2 maps on a stock system…
True, but I’m still not convinced that you will need to.
…I want to have a machine that will run on 91 to 93 octane and higher octane race fuel (116 octane)…
I’m still not sure why. With 91 octane, you’ll probably be disappointed in the performance of your car. Race fuel is hard to find, and terribly expensive. To me, you still haven’t fully considered a solution that would allow you one map, full-time – either water+meth injection or E85.
…That is why I recommended two boost levels also. Map One lower octane, lower boost. Map Two high octane, higher boost…
The oem ecu handles lots of different boost levels, depending on the rpm.
Again, your 3L engine will not be that impressive with the relatively low boost level we’ll need to keep it at for 91 octane. It honestly won’t be that much better than a bone-stock Supra. Marginally quicker, sure. But night-and-day, not even close.
…The reason I am being vague about WHP power is I do not know what the number is due to the two fuel octane choices. …
With 91 octane, your max will be about 450rwhp or so (through your auto trans) with a mid-to-large turbo (with a fair bit of lag). I doubt either would meet your expectations for most of the driving you would do...and please be realistic with me – you’re not going to run race fuel except for rare occasions. Again, I’ve been there and done that. It’s a pain in the butt. However, if you can honestly tell me you'll keep pure race fuel in your tank 33% of the time (or more), you'll change my mind.
Aside: The largest ‘record’ I’m aware of is nearly 700rwhp on 93 octane pump gas, with an absolute monster turbo...but it didn’t make barely any boost at all until about 6800 rpm, and then it went vertical. In the end, nitrous was used to spool this turbo, and it was rarely run on pump gas. When boost ‘goes vertical’, precisely controlling it is very difficult (especially if spooled by nitrous!)…and engine damage occurs if boost limits are exceeded for a given octane of fuel (yes, even with ‘built’ internals).
I appreciate your tight timeframe, your relatively unrestricted budget, and your high expectations. I sincerely believe we can meet all of them. If you’ll allow me, I can keep you from wasting your time (and money). Safety and an overall balanced design will be part of it too. Also believe me when I say, there really is no practical limit to the amount of horsepower you can run on the new C16 race fuel (or the VP Import 120+ octane before it), in a properly modified Mkiv Supra Turbo. This can be a reliable (albeit not necessarily comfortable-to-drive) ride at pretty much any number you care to put down. Try me.
Specifics needed:
- Your max rwhp number. (Again, we can turn down the boost limit at first, without changing anything else).
- Your application (drag racing or roadracing or drifting or autocross or top speed etc.).
- Will this car be 'shown', or will it be a 'sleeper'.
- Is E85 available nearby? Would you consider running it full-time?
http://www.e85locator.net/State%20Pa....html#LasVegas
- How much do you care about it being comfortable to daily drive. Eg. What if the auto tranny has very harsh shifts? What if it doesn't cold-start very well? What if it hesitates a bit on tip-in. What if the torque converter is high-stall and the engine revs and then you get a small bit of wheel spin when leaving most/all traffic lights (especially up-hill)? What if it runs well in the summer but doesn't run well in the winter, or vice-versa? These are all just examples - in general, I need to know how much we can turn this into more of a race car and less of a lexus-like Grand Touring sportscar...and still have you extremely pleased with the results.
Life begins at 30psi.
