Old 11-19-2012, 06:13 AM   #12
ccguy
ccguy is on a distinguished road
if i remember correctly i did not run the fuel pump relay or resistor.
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=70
if i remember correctly i did not run them because i (at the time) only had the inline pump. and i read that it dropped down to like 6v or something like that so i just ran the cor.
i also got a bunch of info off of supracharged.com as well. i will check the volts going to the fuel pump during the stumble and see if they are 12v.
http://www.supracharged.com/tech/wiring/c1.shtml
i will go back over the wiring and let you know how i 100% wired it.
1980 toyota 4x4 truck
1987 7mgte motor, 3" exhaust, water to air intercooler.
4.88s locked, dual cases, lift.....
ccguy is offline   Reply With Quote
