Originally Posted by warmkop
What will the reason be for my powersteering thats noisy after standing for a year
can be a number of things, but easiest check for now would be to rev the vehicle (on park) to about 2k rpm, then turning the wheel all the way to the left until it locks, then all the way to the right till it locks. repeat it several times. the noise is usually due to air bubbles in the fluid. the pump should eliminate the air bubbles.
If however, this does not solve the problem, you may have a damaged line somewhere causing a leak (which would cause air bubbles as well). in a previous post, you mentioned your vehicle overheating, may have damaged some hoses? anyways, we'll start with the easy stuff first and take it from there.
