Old 11-22-2012, 07:15 PM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Ok thanks for the additional info. I'll mull over it for a bit and get back to you with some recommendations (or perhaps some additional questions).
Per our offline discussion, here are a few of my recommendations:
- An endless supply of >110 octane race fuel - for use whenever you're boosting. The ideal fuel is the new C16 from VP Racing Fuels.
- 72mm 'racing-spec' turbo kit
- Full 1000hp fuel system, with lines, pumps and FPR capable of E85 if you change your mind.
- Maintenance items: timing belt, coilpacks, harmonic dampener, diff fluid
- Wider rims & tires
- HKS HiperMax III coilovers
- HKS 272 Cams, ported head, 1mm oversize valves, dual valve springs, L19 studs
- TH400 or 4L80E built transmission
- AEM ECU
- Amuse R100 titanium exhaust
- GReddy 4-row FMIC
- TRD Diff
- Roll cage
Please let me know if you have any additional questions.
Life begins at 30psi.
